Enable OSPF Globally
Enable OSPF globally enabled to use the protocol on the router. If you disable OSPF globally, all OSPF actions cease.
  • Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select OSPF.
  3. Select the General tab.
  4. For AdminStat, select the enabled or disabled option button, as required.
  5. Select Apply.
